Latest: tbafonso
Overall: 17130
Online Now [57]:
Visitors: 56
Today: 15132
Total: 104524736
Forums › The Car › 206 Talk › Climate control backlights
tommyhon23
PostPosted: Sun Sep 15, 2013 2:46 pm Up
So i wanted to change one of the bulbs behind the climate control buttons which i believe are only available on the gti models. Anyway, i got it all off and got the tiny little bulb out but i have no idea what bulb it is? Any ideas what i would type into ebay or ask for in a shop? Cheers
Tom
Peugeot 206 1.4- black
Peugeot 206 gti 180- black
Registration- F1 TPH
Hawkers
PostPosted: Mon Sep 16, 2013 4:09 am Up
www.206info.co.uk/Foru...t=976.html
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
PostPosted: Mon Sep 16, 2013 4:43 am Up
Don't just change one, change them all. They have all been lit for the same amount of time, so chances are that if one has blown, the others will be coming to the end of their lives. Easier to do it once.
PostPosted: Mon Sep 16, 2013 2:29 pm Up
As soon as you disturb any facia/cluster the knocks and movements will definately cause more of them to go out.
All those hours cause the fillaments to go frail with time.
Replace all of them as Macca says as those little lamps are very cheap anyway.
PostPosted: Mon Sep 16, 2013 2:41 pm Up
Just walk into Halfords (or similar) with the bulb...
