Latest: jackrox1992
Overall: 17186
Online Now [692]:
Visitors: 691
Today: 91002
Total: 148621735
Forums › The Car › 206 Problems › What blower do I need.
devildriverxii
PostPosted: Sun Sep 15, 2013 4:03 pm Up
So winter is coming, and I need a new heater/blower in my car, I have an '02 multiplexed with a digital climate control/air con.
I bought one last winter, and it was the wrong one, all I can remember is that it needed a separate resistor...and it was the wrong type of blower for my car.
So Instead of wasting more money i thought I'd ask here to see if anyone knows.
Thanks Smile
2002 1.6 5dr Black Edition.
DREWDEN
PostPosted: Mon Sep 16, 2013 9:20 am Up
Just looked at my old one i removed last year, it has has 2 electric connectors to it.
One is a 2 pin connector and the other is a 5 pin connector.
The resistor is built into it, hence 2 connectors.
206 2ltr Hdi glx 53 plate
dannyboy-gti
PostPosted: Wed Sep 18, 2013 6:20 am Up
When I changed mine i think there were only 2 types for sale, like you mention. I just thoroughly checked the pics on the ebay adverts to make sure there were 2 connectors.
I expect yours has a big metal crescent shaped resistor with spikes on it, under the fan. If the fan works then you could just change the resistor, but when i checked the resistors were a more expensive option
devildriverxii
PostPosted: Thu Sep 19, 2013 7:00 am Up
Cheers for the help guys, I'm guessing I need the 2 connector version then.
DREWDEN
PostPosted: Thu Sep 19, 2013 7:09 am Up
Check my post i did 1n 2011, not good if you don't sort the blower, when its on its way out.
Still have the one in from scrappers and still going strong.
Hope i haven't just jinxed myself Laughing
devildriverxii
PostPosted: Thu Sep 19, 2013 4:11 pm Up
Is it an easy job to replace? could a novice do it? or would it need to be garaged?
tsotd
PostPosted: Thu Sep 19, 2013 5:24 pm Up
glovebox out, twist the old unit out. job done (well dont forget to fit the replacement and replace the glovebox)
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
DREWDEN
PostPosted: Thu Sep 19, 2013 6:06 pm Up
Disconect the battery, then prepare to be a contortionist, can also be a bit tight when trying to twist
anticlockwise to free it.
dannyboy-gti
PostPosted: Fri Sep 20, 2013 9:04 am Up
Spray a little WD40 where it the motor locks into the housing and wait a few mins if it is tight, and it should unlock easily
devildriverxii
PostPosted: Fri Sep 20, 2013 5:54 pm Up
Cheers, so I might as well get it out and check the part number to be 100% sure I'm buying the right part Smile
Will it mess anything up if I drive about without it in for a week or so?
dannyboy-gti
PostPosted: Sat Sep 21, 2013 3:59 pm Up
No, just keep the DAC unit switched off.
