Posted: Wed Sep 25, 2013 10:57 am |
Desperately need some help guys ..
I just purchased a 2003 Peugeot 206. Think it was involved in a driverside smash. That's been sorted but the electric window on the front drivers side door is not working. I checked the switch and wires were cut... can someone please assist by posting a pic of the wiring. Not sure if the switch is faulty... but no power is going through to the window regulator
Posted: Wed Sep 25, 2013 1:18 pm |
No point getting a picture, peugeot never used wiring colours, it's the numbers on the wiring you need to look at.
Posted: Wed Sep 25, 2013 2:59 pm |
How do u know there is no power going to the window regulator? Abut had the door card off?
Posted: Wed Sep 25, 2013 5:42 pm |
Tested it with a multimeter. . Just to make sure I did the door that works.. unplugged the connector to the motor tested the power coming through.. did the same on the other side and no luck. Im not sure if the previous owner tried to reconfigure the wiring.. traces of wires being cut and taped with insulation tape. The switch being original only has 6 of 8 pins.. should be 7?
Switch pins diagram.. (sorry)
Posted: Thu Sep 26, 2013 2:15 am |
Electric windows are easy.
there should be 6 wires.
2 passenger wires
2 drivers wires
1 earth
1 power.
Easiest thing to do would be to test the wires going into the connection block at the switch end. Check to see if there is any volts leaving the switch.
