Latest: Beduff1977
Overall: 17134
Online Now [272]:
Visitors: 271
Today: 231672
Total: 107891685
Forums › The Car › 206 Talk › fan wont work ---- cant figure which fuse it is
daniel.keyte
PostPosted: Fri Sep 27, 2013 10:48 am Up
Can anyone provide me with help.... the fan in my 206 wont turn on all of a sudden.... i have been trying to find a diagram of the fuse box but all of the ones online don't match up with mine.... can anyone help.. i have taken a pic of my fuse box
its a y reg 1.4 206
PostPosted: Fri Sep 27, 2013 2:24 pm Up
The fuse on mine is under the bonnet. Right at the front of the fuse box.
luke079
PostPosted: Sat Sep 28, 2013 8:17 am Up
Should be fuse number 7, In the engine fuse box. Smile
PostPosted: Sat Sep 28, 2013 8:57 am Up
Clue: Its a big fuse!
greenpug2222
PostPosted: Sat Sep 28, 2013 2:26 pm Up
40 amp fuse if I remember.
why wont you work??????????????????? ARGH F**k it!!!!!
