Latest: flipflap
Overall: 17140
Online Now [301]:
Visitors: 300
Today: 71938
Total: 113871854
Forums › The Car › 206 Problems › 206sw various issues
scott40k
PostPosted: Tue Oct 01, 2013 2:43 pm Up
Hi Guys,
we currently have a few weird totally random issues just wondering if any one knows the link or had a similar experience :-
1. intermittent headlights turning on when switched off (wiggling the stalk seems to fix it temporarily, also it doesn't turn the lights off by itself luckily).
2. intermittent indicators that turn off on there own before going round the corner switches them off..(again wiggling the stalk makes it work again)
3. Randomly the overheat indicator will flash up STOP and give some message about the engine is at maximum temp, but it almost immediately it switches off then the message clears and the needle drops to normal (although i'm guessing this is a faulty sensor?)
Thanks for any advise/help
Scott.
iainlovatt
PostPosted: Tue Oct 01, 2013 2:54 pm Up
New comms unit will fix point 1 and 2!
(My Garage)
scott40k
PostPosted: Tue Oct 01, 2013 2:57 pm Up
how much and how difficult to fit would it be?
Tolkienfan001
PostPosted: Tue Oct 01, 2013 3:13 pm Up
Trade Rating: +13
You can buy a new comms from ECP. £100 - £200 depending on spec and current promos on the site.
In terms of fitting.
BSI battery shutdown - guide on here
Remove airbag, steering wheel, then comms unit. All plugs are easily removed and fitting is reverse.
Then reconnect battery and wake up BSI.
2005 1.4 16v Sport
Check out my 206 here!
scott40k
PostPosted: Tue Oct 01, 2013 3:22 pm Up
and what are the chances of it fixing the issue?
Tolkienfan001
PostPosted: Tue Oct 01, 2013 3:33 pm Up
Trade Rating: +13
I would say with the list of issues you have, and the common known fault of the Peugeot comms units it will fix your issues.
2005 1.4 16v Sport
scott40k
PostPosted: Tue Oct 01, 2013 3:36 pm Up
awesome thanks....so is there any point in a secondhand one?
Tolkienfan001
PostPosted: Tue Oct 01, 2013 3:38 pm Up
Trade Rating: +13
No not really. There is a chance it could have faults. For the price of a new one from ECP and the better quality of them it's a no brainier. I changed mine a month after getting the car as it failed. I have had no issues with the one from ECP. And I got it for £110 delivered as the had an offer code on at the time.
2005 1.4 16v Sport
scott40k
PostPosted: Tue Oct 01, 2013 3:42 pm Up
excellent
