Latest: tbafonso
Overall: 17130
Online Now [71]:
Visitors: 70
Today: 10132
Total: 104519783
Forums › The Car › 206 Problems › whole car chugging at idle, But idling great
greenpug2222
PostPosted: Sun Oct 06, 2013 6:56 am Up
Hi,
Odd one this.
This does not happen all the time.
The car idles fine all the time.
The car will on occasion start chugging when at idle but the engine idle is fine and does not move, the car drives fine all the time this only happens at idle.
Ive checked the fuelling and renewed the following sensors in a hope it was one of them.
coolant, map and o2. ive also cleaned the throttle etc etc.
Please can some one point me in the right direction...
why wont you work??????????????????? ARGH F**k it!!!!!
bikesforme
PostPosted: Sun Oct 06, 2013 8:21 am Up
Interesting this one, has my car shakes when started from cold on idle , yet it runs fine once on the move. I have also renewed the 02 sensors, cleaned throttle, renewed the cat, i have noticed a very slight leak on the exhaust, so not sure if that would cause it, has it only leaks slightly. My next call was the coil pack.
greenpug2222
PostPosted: Sun Oct 06, 2013 9:10 am Up
Hi,
It does weather car is hot or cold. Forgot to say I've also changed coil pack (correct one).
I guess it could be the exhaust but why would it do it only say 3/4 times every trip and not all the time ????
It's been happening for approx 4 weeks now and has me well and truly beat.
bikesforme
PostPosted: Sun Oct 06, 2013 9:31 am Up
Do you get any fault lights on the dash, i keeping getting one which is code 130 but it comes and goes.Having just spent near £1200 on the car getting it all sorted, i am not impressed .
greenpug2222
PostPosted: Sun Oct 06, 2013 9:33 am Up
I do not have any warning lights on the dash. My 206 is an old 2000 1.4 model.
bikesforme
PostPosted: Sun Oct 06, 2013 10:15 am Up
Mine is a 2001 1.4 Lx petrol, i should of dumped it but i spent on it hoping it would give me trouble free motoring .
greenpug2222
PostPosted: Sun Oct 06, 2013 12:17 pm Up
I am thinking that I will also have to get rid of it, just wish I could fix it.
bikesforme
PostPosted: Sun Oct 06, 2013 1:12 pm Up
I no u said that there are no fault lights showing on dash, but have u put a code reader on it to see if there are any fault codes showing, and if some are showing clear them off and see if they re-show.Take a note if any show tho.
greenpug2222
PostPosted: Sun Oct 06, 2013 2:20 pm Up
I don't have a code reader.
bikesforme
PostPosted: Sun Oct 06, 2013 3:21 pm Up
I brought mine new off ebay, was only £13
greenpug2222
PostPosted: Sun Oct 06, 2013 3:23 pm Up
Can you point me in the right direction so I can read and delete codes.
bikesforme
PostPosted: Sun Oct 06, 2013 10:09 pm Up
Ebay item 320773110292
I brought this one, very easy to use, comes with full instructions and a book telling you what all the fault codes are.
PostPosted: Mon Oct 07, 2013 1:52 am Up
what about your spark plugs,brand and age?
greenpug2222
PostPosted: Mon Oct 07, 2013 11:16 am Up
Thanks, I'll look at eBay and get one.
Spark plugs are Bosch super plus, in for about 9 months. Car has no problems starting or driving,
bikesforme
PostPosted: Tue Oct 08, 2013 11:33 am Up
Well i have fixed my exhaust leak today, it was only leaking very slightly ,but the fault light has now gone out and the car seems ok at moment.
I put code reader on and codes po130 which is 02 sensor pre cat and code po300 random multiple cylinder misfire showed.
I have now cleared them, lets hope they dont come back.
