Latest: tebas93089
Overall: 17179
Online Now [115]:
Visitors: 114
Today: 17794
Total: 138491516
Forums › The Car › 206 Problems › gear box noise whine!
luna_mick
PostPosted: Mon Oct 07, 2013 5:32 pm Up
my gear box started to whine and chatter slightly a few hundred miles ago . altho it dosent feel clonky or stiff to change gear no clutch slip or vibrations just a high pitche whine and on the down chane a chatter .
now iv herd somewhere youre suposed to change gear oil 80-90 thou is this true or not and if so what oil is it .
if it knackered what should i be paying for a deacent one .
or take a risk on a gt lump and box
oh i drive the y reg 206 1.6xsi 3dr its on 86thou
magistar
PostPosted: Mon Oct 07, 2013 7:34 pm Up
If the whine dissapears when you press the clutch then that could be an indication of input shaft bearings going.
I doubt it would be fixed by a gearbox oil change but could try. I changed my gearbox oil on 100,000km's (60-ish k miles) just out of precaution and the gearbox smoother to shift around. Though best to just bring it to a proper mechanic to diagnose, afterall if you're going to have to do gearbox work, you'll likely have to replace the oil anyways.
luna_mick
PostPosted: Wed Oct 09, 2013 5:24 am Up
The noise does not disappear when the crutch is pressed . The pitch and the volume of the noise increases with the rev .
