Latest: tbafonso
Overall: 17130
Online Now [289]:
Visitors: 289
Today: 45200
Total: 102517408
Forums › The Car › 206 Problems › Removing engine, box and subframe in one?
dannyboy-gti
PostPosted: Fri Oct 18, 2013 11:11 am Up
Hello folks.
Advice please? I have a number of jobs that I'd like to do on the front of my gti138. Clutch, belts, weld manifold, lower arms, check and refresh suspension.
I could do each job one at a time, but is it feasible to remove the engine and box complete with suspension, driveshafts and hubs in one lot?
Would be nice to take my time in a warm garage!
Any experience appreciated.
Danny
PostPosted: Fri Oct 18, 2013 12:57 pm Up
No point. Just one bolt holds the engine to the subframe so makes life easier to take every off separately.
