Latest: Beduff1977
Overall: 17134
Online Now [405]:
Visitors: 404
Today: 51360
Total: 109222291
Forums › The Car › 206 Problems › aftermarket stereo question
alane29
PostPosted: Mon Oct 14, 2013 1:58 am Up
Hello
If i fit a aftermarket stereo will it mess up the display or is there something i need to do ??
thanks
gazza82
PostPosted: Mon Oct 14, 2013 5:22 am Up
It won't use the display if that's what you are asking ...
What year?
Early models (non-plex) are easier as the radio isn't coded to the BSI unit.
But you will also need to get adaptor for the remote stalk if you want to keep it and a fasia adaptor on earlier models where the original radio is not a rectangle!
rlees85
PostPosted: Mon Oct 14, 2013 8:44 am Up
To be honest plexed is just as easy. No facia required. A different stalk adapter is required but it is still plug and play. The display does not display radio information but the clock, trip computer, etc work as normal.
alane29
PostPosted: Mon Oct 14, 2013 9:11 am Up
its a 2004 206s auto
gazza82
PostPosted: Mon Oct 14, 2013 12:39 pm Up
So you won't need a fascia adapter, it won't connect to the MFD (display on top of dash) ... but you will need a remote adapter if you plan to keep it and might need to get BSI reprogrammed to avoid faults.
