Latest: sparrowdclxvi
Overall: 17139
Online Now [90]:
Visitors: 90
Today: 11367
Total: 113211518
Forums › The Car › 206 Problems › Brake light stuck on
RKOT
PostPosted: Tue Oct 15, 2013 9:33 am Up
Hi,
I recently replaced the rear left brake bulb in my '99 206 as it was working with the lights on but not illuminating when braking. After replacing the bulb worked for braking but when i drive with lights on it illuminates as if im braking constantly.
Is there a simple fix for this?
Cheers
PostPosted: Tue Oct 15, 2013 9:37 am Up
Did you put the correct bulb in?
Check the connections and the earth, and make sure the bulb is in the holder properly and the right way round. It's easy to put them in 180 degrees out, and this will give you a dimmer brake light, but a brake light brightness tail light.
RKOT
PostPosted: Tue Oct 15, 2013 9:39 am Up
Was definetly the right bulb, I'll have a play with it and see if that sorts it. Thanks
mattymj
PostPosted: Tue Oct 15, 2013 11:37 am Up
Make sure the bulb has two elements inside. One for the lights and one for braking
RKOT
PostPosted: Tue Oct 15, 2013 1:26 pm Up
Cheers guys i got it working, think it was as macca says and the bulb was upside down.. whoops
