Posted: Thu Oct 17, 2013 10:20 am |
Im about to buy a phase 2 boot trim however its the wrong shade of silver so I want to spray it myself, is it a case of a light sand down,spray colour,then clear lactor?
Cheers
Posted: Thu Oct 17, 2013 11:28 am |
Yes, unless you go down to the plastic, then you will need plastic primer.
Use fine wet&dry and wet it to rub down ...
Posted: Thu Oct 17, 2013 2:39 pm |
Thanks, with it being a darker silver and needs spraying a lighter shade, that shouldn't be a problem should it, in terms of making it even darker when spraying it my colour.
Posted: Fri Oct 18, 2013 6:13 am |
Not if you give it enough coats.
