Latest: S2cgm
Overall: 17178
Online Now [756]:
Visitors: 754
Bots: 2
Today: 22714
Total: 137553965
Forums › The Car › 206 Problems › reving by its self 206 1.4 engine light is on
coolhas
PostPosted: Sun Oct 20, 2013 2:48 pm Up
hi guys i was doing a 70 on the motorway tonight and my engine light came on and some smoke form exhaust and front bonnet turned car off checked could not seem to realize whats wrong
anyways it was fine for 10-15 mins till i got close to home but the car has just started to rev between 2000.3000 rpms by its self with no push on the pedal basically it wants to move on its own its happening in drive with out me doing anything.
i drive a 1.4 206 automatic what could this be?
AidanMurphy
PostPosted: Sun Oct 20, 2013 3:43 pm Up
if it's an automatic I'm guessing the clutch might be an issue if it's wanting to move itself, maybe the ECU, check at a garage is your best bet
PostPosted: Mon Oct 21, 2013 2:53 am Up
What colour was the smoke?
Get a friend to push the accelerator while you look at the throttle body to make sure that the cable is moving freely and the throttle hasn't stuck open. Might be worth cleaning the ICV. (Guide here)
If the EML has come on, a code read is your first step. Once the fault has been identified, then you can go about fixing it otherwise it's just pure guess work.
coolhas
PostPosted: Mon Oct 21, 2013 2:55 am Up
hi thanks the smoke was white grey not black the throttle i have cheecked and seems to be working fine but the car keeps juddering and turning off any help please guys
coolhas
PostPosted: Tue Oct 22, 2013 6:28 am Up
hi guys i was doing a 70 on the motorway in my drive a 1.4 206 52 plate automatic the other day and my engine light came on and some white greyish smoke form exhaust and front bonnet turned car off checked could not seem to realize whats wrong
anyways it was fine for 20 minutes till i got close to home then the engine light came on again but now the car has just started to rev between 2000.3000 rpms by its self with no push on the pedal basically it wants to move on its own its happening in drive with out me doing anything its juddering and just shutting off as i put it into drive the revs drop and it cuts out
could it be due to an symptom of overflow of oil as i did have it serviced about 2 days ago
cheers urgent help needed
PostPosted: Tue Oct 22, 2013 6:42 am Up
Topics merged. You only need one thread active with the same problem.
Have you had the codes read?
coolhas
PostPosted: Tue Oct 22, 2013 7:01 am Up
hi sorry
cant get the bloody thing to move no so haven't had the codes read it just judders shakes revs high by itself then turns off baffling me
coolhas
PostPosted: Wed Oct 23, 2013 8:18 am Up
does no one help on here anymore good god
PostPosted: Wed Oct 23, 2013 8:23 am Up
Unfortunately without the codes being read, it could be any number of things. People could make suggestions on what it might be, but then you could end up throwing money at a problem that doesn't exist.
Someone close by you may have a code reader and will plug it in for a few beer tokens.
coolhas
PostPosted: Wed Oct 23, 2013 12:10 pm Up
i have just had the codes read from garage and its showing up as 2 bad fuel injectors does this seem right to you guys
