Latest: tbafonso
Overall: 17130
Online Now [277]:
Visitors: 276
Today: 8963
Total: 102531771
Forums › The Car › 206 Problems › Permanent live fault?
BlueStu
PostPosted: Fri Oct 18, 2013 5:35 am Up
I have just installed an after market head unit in my daughters 2000 206 lx. To connect to the cars wiring I used a iso lead to bare wires as the head unit lead was to bare wires also. I connected all wires together per instruction manual and handbook, the stereo works fine but loses all stored radio stations when ignition turned off. I have tried swapping the red and yellow wires over but the same problem exists. I have also checked with a multi meter and don't get voltage across permanent live and ground. Not sure where to go next.
Any help gratefully received.
Cheers
PostPosted: Fri Oct 18, 2013 7:56 am Up
A fuse in the fusebox will need moving, but I forget which one sorry!
BlueStu
PostPosted: Fri Oct 18, 2013 10:15 am Up
Cheers for that, I'll have a look into it.
BlueStu
PostPosted: Fri Oct 18, 2013 1:53 pm Up
Fuse 24 for audio just moved it up 1 notch and its sorted.
Thanks again
