Latest: tbafonso
Overall: 17130
Online Now [34]:
Visitors: 33
Today: 12109
Total: 104521750
Forums › The Car › 206 Problems › siezed fuel filler cap
johnboy
PostPosted: Sat Oct 19, 2013 4:39 pm Up
HI all, I've just gone to fill up my 206 gti hdi and when i got to the pump i couldnt undo the filler cap, the key goes in fine but it refuses to turn and undo. I've tried using copious ammounts of WD40 but its still not budging.
Any ideas as what i can do to fix this.
Thanks alot
L5_UKS
PostPosted: Sat Oct 19, 2013 5:16 pm Up
Frozen get a jug of hot water and poor it over it Smile
johnboy
PostPosted: Sat Oct 19, 2013 5:30 pm Up
Cheers for the reply but don't thinks it's frozen as it's been 20c here today.
ollyshep206
PostPosted: Sat Oct 19, 2013 5:41 pm Up
The hot water will help get rid of the corrosion Smile
If in doubt, flat out.
L5_UKS
PostPosted: Sat Oct 19, 2013 5:43 pm Up
Hmm either way I would suggest trying it, Not boiling though as it could damage your paintwork.
johnboy
PostPosted: Sat Oct 19, 2013 6:07 pm Up
Ok cheers guy will go and try it now Smile
L5_UKS
PostPosted: Sat Oct 19, 2013 6:22 pm Up
Let us know how you get on Thumb Up
johnboy
PostPosted: Sat Oct 19, 2013 6:27 pm Up
Just tried but hasn't made a difference Sad
PostPosted: Sun Oct 20, 2013 3:19 am Up
Is it the right key? As in has it been used from another car with a different barrel?
johnboy
PostPosted: Sun Oct 20, 2013 3:23 am Up
That's what I'm beginning to think, I only got one key when I bought it (yesterday) Sad
Tolkienfan001
PostPosted: Sun Oct 20, 2013 3:38 am Up
Trade Rating: +13
Try silicone grease? Then put the key in and give it a tap to make sure it is fully in. If that does not work probably as above wrong key.
2005 1.4 16v Sport
Check out my 206 here!
tsotd
PostPosted: Sun Oct 20, 2013 4:03 am Up
do you have the sp fuel cap?
when i got my 206 someone had fitted the sp cap wrong and was making it really hard to remove it, when i did get the cap off i had to remove the sp cap from the lock and refit it.
in the mean time just keep wiggling/turning and pushing in at the same time just dont got OTT as you might snap the key
Topaz 2.0 16v 205 Gti6 (ph1.5)
Mercury 2.0 16v 206 Gti (ph1)
johnboy
PostPosted: Sun Oct 20, 2013 4:58 am Up
Cheers mate will have a look. Not sure what type I have as I'm new to 206's, it's this one
johnboy
PostPosted: Sun Oct 20, 2013 6:05 am Up
Just spoke to the garage I bought it from and apparently it's the right key as he put fuel in it a couple of weeks ago
rlees85
PostPosted: Sun Oct 20, 2013 6:15 am Up
In my experience from buying cars from people "I put fuel in it a couple of weeks ago" could well be some of his finest bulls**t. With mine, which is the same kind of filler, sometimes I have to push the key inwards slightly as I am turning it but never requires too much force! As mentioned above you really do not want to snap your only key! Spend a good half an hour trying this and that and if it really won't budge and you brought it from a garage I would suggest it is their responsiblity to sort out.
