Online Now [486]:
Visitors: 485
Today: 113425
Total: 106307550
Forums › The Car › 206 Problems › Fuel Gauge Problem
Fuel Gauge Problem
BG101
PostPosted: Mon Oct 21, 2013 8:13 am Up
Hi All,
I have a 53 plate 1.4 HDI.
The problem I am having is that the fuel gauge is not working and the fuel light is always on.
If I lift my back seats and give the cables connected to the fuel pump a wiggle, it used to work and the fuel gauge would go up to show how much is left. but would never re-set after filling up again. Now that doesn't reset it.
I thought is was the pump at first until discovering that playing with the cables reset it so now I don't really know. It could just be a faulty cable.
Anyone ever know or had this issue before?
Also, does anyone know where I can find a new cable from?
I can not find the cable anywhere online, or it could be that I don't know what I am looking for.
BG
DREWDEN
PostPosted: Mon Oct 21, 2013 12:10 pm Up
Seems to me that when you are, tugging and playing around with the cable, it is a bad connection inside the
connector itself, take the connector off, and give a good clean, the copper connectors can become a bit green and mouldy looking.
206 2ltr Hdi glx 53 plate
BG101
PostPosted: Tue Oct 22, 2013 4:40 am Up
Thanks Drewden,
I'll give it a go later.
Can anyone recommend the best way to clean connectors? I'm sure I read somewhere a certain spray is best.
PostPosted: Tue Oct 22, 2013 5:11 am Up
Electrical contact spray.
BG101
PostPosted: Fri Nov 01, 2013 4:34 am Up
Thanks all.
So far so good.
