Latest: Beduff1977
Overall: 17134
Online Now [1050]:
Visitors: 1049
Today: 25264
Total: 107685537
Forums › The Car › 206 Problems › Driving with little or no power steering fluid?
very_452001
PostPosted: Tue Oct 22, 2013 7:07 am Up
Does it cause damage to steering components caused by friction?
Which power steering fluid should I get?
very_452001
DREWDEN
PostPosted: Tue Oct 22, 2013 8:30 am Up
Haynes manuel says Total Fluide LDS.
All fluids that are low in a car is obviously not good for mechanical parts, barring screen washer of course.
Take it you have had a leak and fixed it.
206 2ltr Hdi glx 53 plate
very_452001
PostPosted: Tue Oct 22, 2013 10:00 am Up
Just realised the problem today. I see if there is a leak once I top it up.
very_452001
DREWDEN
PostPosted: Tue Oct 22, 2013 10:37 am Up
Just to add should be 3 markers on the dip stick, top up between bottom 2 markers, as when fluid is warm it expands and will then read higher up the stick.
gazza82
PostPosted: Tue Oct 22, 2013 11:47 am Up
Yes ... unless for a very short distance ...
DSWR
PostPosted: Tue Oct 22, 2013 11:57 am Up
Power steering is only active at low speeds, so as long as you drive it like it's a rally car, it'll make no difference at all, haha.
GTi 180 owner!:)
www.facebook.com/notdanwhite
very_452001
PostPosted: Tue Oct 22, 2013 5:06 pm Up
Crap! I been driving it (non rally style) all these months and just realised the problem now.
What damage do you think I have caused? So far I havent noticed anything while driving.
I bought this power steering fluid:
any good?
very_452001
PostPosted: Tue Oct 22, 2013 5:17 pm Up
There is only one way to find out if it is damaged - wait and see. It could range from you having got away with it to being knackered in a couple of months.
Wait and see!
very_452001
PostPosted: Sun Jun 08, 2014 10:27 am Up
Im suspicious that my power steering fluid is leaking as I remember topping up to the max 7 months ago and today when I checked the fluid level it is totally dry. Plus I can see dark wet patch on the driveway where I park my car. I think I should worry unless the 206 is power steering fluid thirsty car?
What are the common causes of power steering fluid leakage? Is there a diagram/picture that shows schematics of the power steering system of the 206?
very_452001
TonyW
PostPosted: Mon Jun 09, 2014 1:21 pm Up
Mine recently went totally, the pas pipework runs across the front of the bumper and was wearing a hole, just leaking a little at first and then eventually went! Typically whilst I was 200miles from home at the time!
Drove it home, V STIFF! and then took it to the garage. He replaced the pipe (£150 inc labour i think it was) but said the pump was whining due to being run dry and advised its replacement.
Thankfully his spanner monkey broke it so i got a new one for freeeeeee!!!!
Just right under the lip of the bumper is where it clips, have a look as if it's not properly secured it will rub...
very_452001
PostPosted: Tue Jun 10, 2014 10:27 am Up
Ok what about products like these that claim to stop leaks:
www.halfords.com/webap...yId_255219
Do they work?
Also in 206 beginners guide in this forum it states that a 206 PSF reservoir takes 1litre max of power steering fluid. For real?
very_452001
PostPosted: Tue Jun 10, 2014 11:16 am Up
Damaged pipework, defective pump or failed seals in the hydraulic system on the steering rack.
very_452001
PostPosted: Tue Jun 10, 2014 12:42 pm Up
Which is the most worst case expensive scenario? How do I diagnose which cause it is?
However I notice my steering is not stiff. From this comment can you narrow down the problem?
Also the link I posted earlier that takes you to a product that claims to fix PSF leaks. Does that really work?
very_452001
