Latest: tbafonso
Overall: 17130
Online Now [58]:
Visitors: 57
Today: 41289
Total: 104453443
Forums › The Car › 206 Problems › Horn Not Working
Horn Not Working
snowdude2004
PostPosted: Wed Oct 23, 2013 3:35 pm Up
Hi All,
My horn isnt work on moy 206 1.1 52 plate.
When the horn is pressed there is a clicking noise at the fusebox under the car bonnet.
When I look at the horn from above I can see two connector in the horn area, one is plugged in and the other is dangling.
Does anyone have a picture of what it's meant to look like/able to advise?
Black Peugeot 206 1.1, body kit, bucket seats, clip on exhaust etc...
mtempsch
PostPosted: Sat Nov 02, 2013 10:07 am Up
The clicking probably means the relay is doing what it should. A common problem with the horn are corroded wires/connectors, IIRC Peugeot even has a partial wiring kit available toreplace the last piece out to the horn.
I'd disconnect the wires/plug from the horn and inspect the contact elements and the wires going into them. Then plug a multimeter into the 'car' side and try the switch on the steering wheel...
If that's OK then try to apply +12V and ground via temp wires, directly from the battery to the horn to see if the horn itself is OK.
Silvermetallic 2004 206 RC
gazza82
PostPosted: Sat Nov 02, 2013 1:10 pm Up
Hard to get a pic in-situ as the horn is buried down behind the bumper. If one of the connectors is brown it's probably the one that is clipped up higher on ours seems to be something to do with the alarm (we don't have one, so it's not connected to anything).
If you feel down to the left side of the rad as you are standing looking in the bonnet you should be able to feel the connector .. where it is placed means it gets wet a lot so corrosion is a probable cause.
If you can get the connector off check you are getting power to it using a multimeter .. if you have then it's corroded connectors or a duff horn.
