Posted: Fri Oct 25, 2013 6:35 am |
Hi everybody
Could someone please help with some advise on how to remove the power steering hose fron the steering rack. One of my hoses developed a leak and its driving me insane on all the smoke coming from my car.
Please help me. 206 1.6 xt
Many thanks
Posted: Fri Oct 25, 2013 8:22 am |
Isn't it just a single torx bolt holding the clamp on the pipes?
Posted: Fri Oct 25, 2013 8:23 am |
It is. Its just I mission to get to it. There isnt much space where you can work to loosen it.
Posted: Fri Oct 25, 2013 8:42 am |
Through the wheel arch might be easiest.
Posted: Fri Oct 25, 2013 8:57 am |
Thank you very much. Will try that now.
