Latest: Stu-mill
Overall: 17131
Online Now [31]:
Visitors: 31
Today: 4435
Total: 104914096
Forums › The Car › 206 Problems › power steering hoses
carlw
PostPosted: Fri Oct 25, 2013 6:35 am Up
Hi everybody
Could someone please help with some advise on how to remove the power steering hose fron the steering rack. One of my hoses developed a leak and its driving me insane on all the smoke coming from my car.
Please help me. 206 1.6 xt
Many thanks
PostPosted: Fri Oct 25, 2013 8:22 am Up
Isn't it just a single torx bolt holding the clamp on the pipes?
carlw
PostPosted: Fri Oct 25, 2013 8:23 am Up
It is. Its just I mission to get to it. There isnt much space where you can work to loosen it.
PostPosted: Fri Oct 25, 2013 8:42 am Up
Through the wheel arch might be easiest.
carlw
PostPosted: Fri Oct 25, 2013 8:57 am Up
Thank you very much. Will try that now.
