Forums › The Car › 206 Problems › What's this part |
Posted: Sat Oct 26, 2013 4:05 pm |
I know sounds like a stupid question I know but just dropped the panel under the steering wheel to plug in diagnostics and this box fell out, not secured to anything, but my manual isn't here yet so thought I'd ask the experts.
Thanks guys
Posted: Sat Oct 26, 2013 8:01 pm |
looks like an immobiliser unit to me, or airbag module? usually thats in centre though.
Posted: Sun Oct 27, 2013 2:02 am |
As James says, airbag module is in the centre, just in front of the gear stick.
Immobiliser is built into the cars electronics.
Looks like an aftermarket alarm or tracking device to me. Can't see the writing clearly to tell properly.
Could the car have been fitted with a black box as part of the insurance policy?
Posted: Sun Oct 27, 2013 4:55 am |
Not sure really. I Will try and get a decent pic of the writing.
Posted: Sun Oct 27, 2013 5:01 am |
It's a Magneti Marelli part so will be standard.
