Latest: Beduff1977
Overall: 17134
Online Now [330]:
Visitors: 329
Today: 71002
Total: 107176354
Forums › The Car › 206 Problems › big fuel problem
big fuel problem
dafdavies
PostPosted: Sat Nov 02, 2013 10:40 pm Up
Manage to snap the connector to the fuel filter Any way of a quick fix Need to get the car home
Team: If you cant find the tool you need make one
DREWDEN
PostPosted: Sun Nov 03, 2013 6:20 am Up
Have you got it sorted.
206 2ltr Hdi glx 53 plate
PostPosted: Sun Nov 03, 2013 9:47 am Up
Seems a funny thing to play with at 3am...
