Latest: Beduff1977
Overall: 17134
Online Now [727]:
Visitors: 726
Today: 72473
Total: 107253285
Forums › The Car › 206 Talk › bit of pipe
bit of pipe
marshy206
PostPosted: Sun Oct 27, 2013 7:56 am Up
Hi can anyone tell me what the bit of tube pipe going from the battery housing to just behind the radiator is for its a 1.4 8valve thanks
Lex206
PostPosted: Sun Oct 27, 2013 11:33 am Up
to cool the battery?
Megane 225 RS
greenpug2222
PostPosted: Sun Oct 27, 2013 1:09 pm Up
Drainage I think.
why wont you work??????????????????? ARGH F**k it!!!!!
PostPosted: Sun Oct 27, 2013 1:12 pm Up
More likely to be a vent to cool the battery or vent any gasses away.
PostPosted: Sun Oct 27, 2013 3:07 pm Up
it's a battery cooler line,as the battery gets so hot when there is load,so for longer life and better performance it needs to be cold.
marshy206
PostPosted: Wed Nov 06, 2013 10:35 am Up
thanks and ok because it came off so i left it of guess i had better put it back on lol
usher
PostPosted: Wed Nov 06, 2013 10:55 am Up
what about when locating the battery in the car does it need to be in a box ??
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
mtempsch
PostPosted: Thu Nov 07, 2013 12:32 am Up
Hydrogen gas can be generated when charging or rapidly discharging. Mixed with air it's combustible in most ratios and very explosive in some...
There are normal lead-acid starter batteries that are sealed but have a small port that will accept a nozzle for a hose to be routed outside (for instance when mounted in the trunk). In that case no box is needed.Then there's the fully sealed lead-acids and glass-matrix bound ones, but even these have valves to release gas if conditions go bad enough (rather than crack the case...)
Silvermetallic 2004 206 RC
