Latest: cogeim7
Overall: 17185
Online Now [758]:
Visitors: 757
Today: 183046
Total: 147081396
Forums › The Car › 206 Problems › 206 hdi 2.0 litre 2001 will not start
leenicholson206hdi
PostPosted: Thu Nov 07, 2013 5:10 am Up
hi after changing aux belt on my 206 car would not start ..battery went flat there is now NO EML showing at all ever ....it is a non preplexed model so dont know how this has occured any one in coventry area that can help with diagnosding this as peugeot dealers cost massive amounts|| thanks
PostPosted: Thu Nov 07, 2013 10:13 am Up
Check closely that you haven't disloged any electrical plug connectors while doing the work.
Also have a close look and make sure there aren't any broken wires - heavy or small gauge. It wouldn't be the first time that corroded cables have broken just by being touched.
PostPosted: Thu Nov 07, 2013 2:15 pm Up
Does this make it multi-plexed then! Rolling Eyes
What is happening when you turn the key? Does the engine turn over or is there nothing?
What lights are coming up on the dash when you turn the ignition on?
So many things it could be, with so little information given.
leenicholson206hdi
PostPosted: Fri Nov 08, 2013 5:11 am Up
when i turn key to ignition pos 3 ... the 3 red lights come on the right hand side of dash... handbrake ...oil...battery light.....then the orange abs warn light illuminates the glow plug light is on for 1 second ....and the TOP light is on ......when i turn the key to start i just get no inclination that its gonna fire up....i hear the fuel pump fire up when first turn ign on ........
DREWDEN
PostPosted: Fri Nov 08, 2013 7:22 am Up
I take it the starter motor is not spinning, (is it just a clicking noise) check the main earth lead from the battery tight and clean. If that is ok check the wires to the starter moter, if that is ok, tap on the starter motor while turning the key.
206 2ltr Hdi glx 53 plate
leenicholson206hdi
PostPosted: Fri Nov 08, 2013 7:57 am Up
the starter motor is turning yes ............ just cleared codes on it ...still no EML light still not starting
PostPosted: Fri Nov 08, 2013 11:30 am Up
Have you tried the spare key?
