Online Now [1208]:
Visitors: 1207
Today: 262451
Total: 149325336
Forums › The Car › 206 Problems › Oil Level Gauge Fault
20Drift
PostPosted: Fri Nov 08, 2013 8:35 am Up
Hi Guys,
Every so often, my oil level indicator on the dashboard will flash for a few seconds before starting the car - according to the handbook there's an Oil Level Gauge Fault.
Does anyone know what to look for, and how to rectify?
Thanks!
PostPosted: Fri Nov 08, 2013 11:26 am Up
How many squares and lines do you have when it flashes and how does this level compare to the physical check using the dipstick?
Try a BSI reset and see if that cures it.
20Drift
PostPosted: Fri Nov 08, 2013 8:30 pm Up
When the fault is there, just the flat lines flashing. When it does read, all the boxes are present - the dipstick is just under full.
Will try tomorrow
