Latest: lio94
Overall: 17181
Online Now [278]:
Visitors: 277
Today: 65489
Total: 141932557
Forums › The Car › 206 Problems › Gti 180 feels unsafe
standardgt180
PostPosted: Fri Nov 08, 2013 9:22 am Up
ok I am no expert mechanic but I know a fair bit . I have a standard gti 180 2004 that has a mind of its own and hase lots of play in the steering wheel where as when I got the car 4months ago it felt tight . so I have changed the tie rod ends replaced the drop links and both arms have had two new tyres on the back and two part worns on the front , there is no play in any of the bearings that I can see , on the odd occasion esp/asr not function pops up . im goin on holiday in two weeks so looking for the cheapest and best way to diagnose this problem any help would be appreciated thanks
Lecktorious
PostPosted: Fri Nov 08, 2013 12:38 pm Up
Trade Rating: +59
There is no cheap way to fix it. Either take it somewhere can can pin point the problem or keep replacing parts until you've fixed it.
'98 Nile Blue 306 GTi 6
PostPosted: Fri Nov 08, 2013 1:17 pm Up
Could be the part worns. You never really know the history of part worn tyres.
broadblaster
PostPosted: Fri Nov 08, 2013 1:47 pm Up
as above i do not trust part worns or secondhand tyres i supose you could try swapping the rear wheels with the fronts and see if that makes any diffrence.
on a back road playing
standardgt180
PostPosted: Sat Nov 09, 2013 10:50 am Up
I have a feeling that its the driveshaft , I have a 138 gti sat in the garage for spares would the drive shafts be the same , I know there is a difference in the gearbox so not to sure if they fit . good point with part worns although one of the tyres was already on the rear of my car , I did notice that the casing around the abs sensor is cracked I cant see this being a problem ?? thanks for your input
PostPosted: Tue Nov 12, 2013 7:29 am Up
Check tyre pressures.
Has tracking been set after replacing parts?
Worn rear stub axle allowing rear wheels to wander and steer the car from the rear.
Front bottom swivel joint(s).
Front wishbone(s).
+1 Lectorious. You are obviously in above your head. Get someone more knowleageable to have a look.
I would never use part worns but did this start at there same time that they were fitted or soon after. Is the tread starting to lift from the carcass or any other bulges or unusual tyre deformation.
standardgt180
PostPosted: Tue Nov 12, 2013 9:46 am Up
I will have someone have a look just working 6nights a week 12 hour shifts its abit tricky when I only have sundays of . yh the problem happened soon after and to be honest tyres pretty decent , I am goin out there now to swap the part worn to the back and see whats going on
PostPosted: Wed Nov 13, 2013 2:45 pm Up
When you are working 16 - 19hr shifts come back and complain. Until then get on with life.
