Online Now [356]:
Visitors: 355
Today: 4969
Total: 143422766
Forums › The Car › 206 Problems › steering
steering
gizmothedog
PostPosted: Sun Nov 17, 2013 2:09 pm Up
Hi fellas,
Had my 206s for about 4 Weeks. 04 with 65k. Seems to be an issue with the steering. When setting off from a junction and the steering is turned it seems to be quite stiff and then goes back to normal once you set off. Doesn't make any noises just a stiff spot. Is this normal operation of is is something to be concerned about. My Mrs seems to think its got worse since putting a full set of winter tyres on but I'm not sure.
Thanks in advance Very Happy
DREWDEN
PostPosted: Sun Nov 17, 2013 2:41 pm Up
Are the tyre pressures ok.
Is the tracking ok.
Whats it like at a standstill putting full lock left to right a few times.
206 2ltr Hdi glx 53 plate
PostPosted: Sun Nov 17, 2013 2:57 pm Up
I believe you have a problem with your C.V joint
gizmothedog
PostPosted: Sun Nov 17, 2013 3:45 pm Up
I'll try it tomorrow and let you know. There is an advisory on mot for a cv boot....
PostPosted: Tue Nov 19, 2013 3:19 pm Up
so any news?
