Latest: tbafonso
Overall: 17130
Online Now [384]:
Visitors: 383
Today: 97581
Total: 103023133
Forums › The Car › 206 Problems › Shock Absorber Bolts Which way round?
A10PSW
PostPosted: Wed Nov 27, 2013 12:47 pm Up
Does it matter which way round the bolts go in on the Shock absorbers for my 2005 206 1.4HDI?
ie Nuts on the inside or outside?
PostPosted: Wed Nov 27, 2013 12:58 pm Up
Rear? For the top the bolt head goes on the outside, at the bottom the bolt head goes on the inside.
A10PSW
PostPosted: Wed Nov 27, 2013 1:09 pm Up
Thanks Edward, I wondered why it came loose after changing the axle!
PostPosted: Thu Nov 28, 2013 1:55 am Up
I bet this is from memory. Smile
PostPosted: Thu Nov 28, 2013 2:21 am Up
It is actually. I double checked with my photos too!
I doubt it really makes a difference though. They are probably inserted a certain way as it's easier in production. Getting the top bolt in from the outside with the wheel still in place can be difficult though.
PostPosted: Thu Nov 28, 2013 11:59 am Up
It really won't make a difference, just whatever is easier for you to work on.
