Posted: Mon Dec 02, 2013 4:44 am |
Hi,
as described, after i have been driving for a short while the car starts to give off a rubber like burning smell.
Its only been going on about a week but has got worse.
I have a 2000 1.4 Roland Garros Auto.
Any help would be rather helpful.
thanks in advance
Karl.
Posted: Mon Dec 02, 2013 7:46 am |
Don't suppose you have had a new clutch fitted recently, can smell a bit whilst bedding in.
Check front and back brakes after a run out, touch the drums and calipers and see if excessive heat is coming off any, you will know if any are sticking by compareing.
| 206 2ltr Hdi glx 53 plate | |
Posted: Mon Dec 02, 2013 8:07 am |
Check what Dresden says, also check your aux belt as it could have stripped a tooth
| You never really learn to swear until you learn to drive | |
Posted: Mon Dec 02, 2013 2:15 pm |
| DREWDEN wrote: |
| Don't suppose you have had a new clutch fitted recently, can smell a bit whilst bedding in. |
It's Automatic
Well make sure that your cooling fans are working,because it might be over heating causing this smell.
Posted: Tue Dec 03, 2013 5:26 am |
the fan kicks in all the time, has done since i bought it back in may..
the car can be running for 2 mins from cold and the fan kicks in.
Brakes are good already thought of that one myself..
Posted: Tue Dec 03, 2013 6:46 am |
Check your coolant temperature sensor. Green plug
Posted: Tue Dec 03, 2013 12:10 pm |
Make sure nothing is touching the exhaust, especially the hand brake cables
Posted: Tue Dec 03, 2013 12:19 pm |
have you had an oil change recent ? sometimes a bit of oil gets onto the exhaust manifold and gets burnt off.
are your oil and coolant levels staying constant ?
