Latest: Kifi69
Overall: 17183
Online Now [500]:
Visitors: 499
Today: 11575
Total: 144303215
Forums › The Car › 206 Talk › heater matrix pipe HELP!
Forum Index › 206 Talk
clackaberry
PostPosted: Thu Dec 05, 2013 10:51 am Up
HI PUG OWNERS
PEUGEOT 206 1.4 PETROL X REG
i have a leak on the heater matrix pipe inside the car tht joins the matrix radiator which has 3 bolts on it, does anyone know if there is a gasket or
O-ring seals inside thanks
2stroke
PostPosted: Thu Dec 05, 2013 3:22 pm Up
I had the same leak, however mine only had 1 nut bolt so put in 2 extras. the torque/tightness of these fasteners is low to not over compress the seal. I found scale in the connection in mine, cleaned it up, refitted, and job done after coolant change and careful bleeding, leak gone.
PostPosted: Thu Dec 05, 2013 4:26 pm Up
Only about 15 quid for that bit of pipe and seals genuine
