Latest: lio94
Overall: 17181
Online Now [132]:
Visitors: 132
Today: 12286
Total: 141509657
Forums › The Car › 206 Talk › Steering wheel slightly off centre
NayNay1991x
PostPosted: Tue Nov 26, 2013 3:30 am Up
Hey there, my steering is slightly off centre the car doesn't pull to one side but when I move the steering to the dead on centre it moves over to the right? Is it just tracking needing doing I had it done about 8 month ago -.-
206 1.4i GLX 1999
instagram.com/nay206pug/#
Uz
PostPosted: Tue Nov 26, 2013 4:01 am Up
Adjust the steering wheel. Wont cost you anything.
millow_99
PostPosted: Thu Nov 28, 2013 1:33 pm Up
Just done mine today! This was a hard week for me, redoing the front suspension! Had the steering wheel problem which was slightly off. I went and did an alignement and it fixed it. Wanted to try the previous method but the thought of not re-fitting it right made me squirm!
Pug Lover!
DSWR
PostPosted: Tue Dec 03, 2013 9:09 pm Up
The nightmare of front suspension! I remember when I did mine. My wheel was off by about 40 degrees! was pretty damn comfy.. Kind of wished I left the steering wheel as it was, aha!
GTi 180 owner!:)
www.facebook.com/notdanwhite
Thedevonian
PostPosted: Wed Dec 04, 2013 8:37 am Up
You need to get the tracking done again to put the steering wheel straight. They should place a device on the steering wheel to keep it straight which rests on the seat, then they adjust the tracking and a quick road test is the only way to confirm if the wheel is really straight afterwards. You can't simply move the steering wheel a spline or two to get it straight because there is one larger spline at the bottom meaning the steering wheel can only go on in one position.
2008, 206 1.4 Look
PostPosted: Wed Dec 04, 2013 9:15 am Up
Lazy mechanic adjust only one TCA which puts the steering wheel out. They should adjust both sides equally if they are doing the job properly.
PostPosted: Wed Dec 04, 2013 7:01 pm Up
You must be joking.
DSWR
PostPosted: Wed Dec 04, 2013 7:09 pm Up
V9977 wrote:
You must be joking.
Could always remove the steering wheel and place it back down straight if there's the know how.
GTi 180 owner!:)
PostPosted: Wed Dec 04, 2013 7:48 pm Up
DSWR wrote:
V9977 wrote:
You must be joking.
My God, either you lot are taking the pιss or this place has well and truly had it.
I hope it's the former.
DSWR
PostPosted: Wed Dec 04, 2013 8:15 pm Up
V9977 wrote:
DSWR wrote:
V9977 wrote:
You must be joking.
Nothing wrong with my method. Typically the steering wheel is off from wheel alignment, the mechanic forgets to make sure the steering wheel is straight, then adjusts the wheels central. I've replaced my peugeot steering wheel for the red and black cc one, it's not the hardest thing in the world...
GTi 180 owner!:)
gazza82
PostPosted: Thu Dec 05, 2013 6:13 am Up
DSWR wrote:
... the mechanic forgets to make sure the steering wheel is straight, then adjusts the wheels central ...
So that would suggest he hasn't done the job properly and your tyres are going to scrub pretty quickly.
It's also not always possible to move it as it still is offset due to he splines .. and on some cars it has to go in a certain position or the indicators, etc and out of sync ... hence why turning one way flicks them off quicker that the other.
Take it back and get them to re-do the alignment properly including the steering wheel ...
PostPosted: Thu Dec 05, 2013 6:15 am Up
DSWR wrote:
V9977 wrote:
DSWR wrote:
V9977 wrote:
You must be joking.
My God, either you lot are taking the p?ss or this place has well and truly had it.
Just moving the steering wheel doesn't solve the issue of why it's misaligned in the first place.
If it's because the tracking is out, it's still going to scrub the tyres and be more expensive in the long run, not to mention the safety aspect if the car isn't cornering properly.
We're becoming a world of Duck tape and WD40 repairers.
doski
PostPosted: Thu Dec 05, 2013 2:52 pm Up
in general my steering wheel feels loose porobably get 30 degrees each way without any bite
DSWR
PostPosted: Thu Dec 05, 2013 6:13 pm Up
macca1411 wrote:
DSWR wrote:
V9977 wrote:
DSWR wrote:
V9977 wrote:
You must be joking.
I took it as the wheels were aligned but the steering wheel itself was out
GTi 180 owner!:)
