Latest: Beduff1977
Overall: 17134
Online Now [3317]:
Visitors: 3316
Today: 113219
Total: 107514874
Forums › The Car › Solved 206 Problems › Judder but still performing ??
Go to page Previous  1, 2
19Connor92
PostPosted: Wed Apr 16, 2014 10:55 am Up
have the same thing on my GTI 180 but had the injectors cleaned and tested bout a year ago but that never made a difference. going to drop subframe and sort out manifold see if that makes a difference.
nice one posting thou should help loads of people out.
schejk
PostPosted: Fri Jun 20, 2014 12:09 am Up
hi, which bluetooth connector did you buy?
PostPosted: Fri Jun 20, 2014 2:28 am Up
As for cleaning the MAF sensor...I don't think any petrol 206 has one.
206Info_SW_Scots
PostPosted: Mon Aug 11, 2014 9:31 am Up
Hi,
It's an ELM OBD 2 one. It's Bluetooth and many free apps for your phone or tablet so you can connect it and drive about to read codes or data etc. you can run it for a week to get a good mpg average for instance.
£7 so pretty cheap.
www.ebay.co.uk/itm/lik...p;ff14=108
206 SW 55 Plate - Happy Owner
Page 2 of 2
