Posted: Fri Dec 20, 2013 2:30 pm |
206gti 180
53 plate
I have just purchased a standard head unit and installed it in the car it works perfectly apart from every 5 seconds there's a loud beep?
Not a clue what this could even be, display is reading the right things and it is the same no matter what you try and change.
Any help would be much appreciated
| | ![](images/spacer.gif) |
Posted: Fri Dec 20, 2013 3:25 pm |
Well that have been covered before,but I will answer it anway :),well it beeps because the code of this head unit is the VIN of your car,and since you bought it from scrappy or ebay or what ever,it got the VIN of the car that had it on,so when you install it on your car,it's like using a stolen head unit,so that is why it beep every 5 seconds.
To fix this problem,you need to find someone who got a PP2000 (Peugeot Planet),so he can decode it,with entering your car VIN to the headunit,simple job,take about 5 min. and all will be ok.
PP2000 Map
Posted: Sat Dec 21, 2013 5:00 am |
how about when preplex install aftermarket radio, still got beeping sound
Posted: Sun Dec 22, 2013 10:43 am |
heyziq wrote: |
how about when preplex install aftermarket radio, still got beeping sound |
No,the beeping is for Mux,and the code request for preplex,only when using OEM headunit.
Posted: Sun Dec 22, 2013 9:24 pm |
Timon2210 wrote: |
heyziq wrote: |
No,the beeping is for Mux,and the code request for preplex,only when using OEM headunit. |
im using sony headunit on preplex, is it normal for beeping sound?
Posted: Mon Dec 23, 2013 10:08 am |
Sony headunits make an annoying beeping sound if you don't remove the front panel when you are leaving the car.
Only OEM headunits make this beeping sound when turned on if the headunit isn't configured with PP2000.
| 306 S16, 306 GTI-6, 605 SV24, 205 GTI-6, 2x405 Mi16, VW T3 1.9TD/AAZ, Audi TT mk2 3.2 quattro, Audi A6 2.7 biturbo quattro | |
