Forums › The Car › 206 Problems › 1.6 hdi radiator replacement |
Posted: Fri Dec 20, 2013 7:49 am |
2005 1.6hdi
After over a year of having a slight leak in my radiator all of a sudden it's gotten worse and i've had to buy one.
Is it relatively simple to change one yourself?
I need a guide or a walkthrough if anyone has one?
Cheers
Posted: Fri Dec 20, 2013 12:55 pm |
Dead easy, 4 bolts. Couple connectors and 2 pipes
Posted: Fri Dec 20, 2013 3:56 pm |
it's the simplest thing you can ever do by yourself,nothing tricky in it,straight forward job,but don't forget to bleed the coolant system when you are done.
Posted: Mon Dec 23, 2013 3:26 am |
Are the bolts the torx ones on the top?
Posted: Mon Dec 23, 2013 9:03 am |
Yes they are the ones that hold the top of the radiator in place.
