Latest: jackrox1992
Overall: 17186
Online Now [831]:
Visitors: 830
Today: 136029
Total: 148288246
Forums › The Car › 206 Problems › Knocking/Clunk noises while driving?
very_452001
PostPosted: Thu Nov 14, 2013 6:56 pm Up
Sometimes while driving I can hear Knocking noises that sounds like its coming from underneath the car.
What is causing these noises?
very_452001
DREWDEN
PostPosted: Thu Nov 14, 2013 8:25 pm Up
Do you mean a mechanical knocking noise.
Or something is loose knocking noise.
206 2ltr Hdi glx 53 plate
very_452001
PostPosted: Fri Nov 15, 2013 5:16 am Up
No metallic noises like metal hitting into each other although it could be that from my perspective in the cabin.
If it was something loose it would make make a constant noise i believe.
very_452001
PostPosted: Fri Nov 15, 2013 5:29 am Up
Have a look at the exhaust heat shield to see if it's been touching the exhaust.
PostPosted: Fri Nov 15, 2013 11:12 am Up
Drive sharfts & engine mounts?
gazza82
PostPosted: Fri Nov 15, 2013 12:23 pm Up
Suspension arms, drop links, roll bars, ...
hilton_marc
PostPosted: Sat Nov 16, 2013 1:05 pm Up
I've got exactly the same problem, just got my car mot'd passed with no issues but got mechanic to jack it up and check if he can see anything loose for this annoying knocking rattling noise but there was nothing loose expect he mentioned about my exhaust had a box missing in the middle :/ ( not sure if this is true) which it could be he said , for me the time it makes most noise is if you lift your clutch up to biting point and when my car is on choke.
very_452001
PostPosted: Mon Dec 16, 2013 6:45 pm Up
yeah i notice the noise when clutch at biting point. What can it be?
very_452001
