Latest: tbafonso
Overall: 17130
Online Now [358]:
Visitors: 357
Today: 30374
Total: 103892533
Forums › The Car › 206 Problems › gti hdi leaking injector
johnboy
PostPosted: Sat Dec 14, 2013 3:40 pm Up
hi all, i've noticed i have a leaking injector, is it just the copper washer that needs replacing or is it worth replacing all of the seals while the injector is out.
thanks in advance
PostPosted: Sun Dec 15, 2013 3:16 pm Up
If your asking this, i advice you pay someone to do it
As you have to have a injector cleaner tool, as a slight bit of ingress down were the injector seats will make it leak again. I always advise doing four if the carbon level is touching another injector or two or more are leaking
Plus also you have to be meticulously clean when doing the job
will-sussex
PostPosted: Sun Dec 15, 2013 6:11 pm Up
just done one on a 1.4hdi, managed to borrow a seat dressing/cutting tool off local mechanic!
206SW 1.4HDI
