Latest: Kifi69
Overall: 17183
Online Now [374]:
Visitors: 372
Members: 1
Today: 28992
Total: 143577729
Forums › The Car › 206 Problems › Weird ABS/ESP fault on a GTI180
Kale
PostPosted: Mon Dec 16, 2013 3:06 am Up
The car is a 2003 model GTI180 (or a RC as we call them here in Finland). It is owned by a friend of mine and I'm tackling with this matter now.
During last winter the car came up with a ABS fault warning, ABS brakes and ESP stopped working of course. It wasn't a concern at that moment because MOT wasn't due untill now.
The car owner replaced both front ABS sensors and it didn't help at all.
A couple of months ago the codes were read and they informed that the ESP ecu had low voltage sometimes (?) and the left front ABS sensor had a fault that was "internal". This was curious because the dealership said that sensor faults are usually open circuits or similar and they had never before seen "internal faults" on these.
Well, as a Peugeot enthuasist I bought myself a PP2000/Lexia cable set and started looking around. The low voltage fault goes away when the fault codes are reset (and comes back occasionally) but the front left sensor internal fault stays on no matter what.
While looking at the live data feed from the sensors it reads that the voltage is fine, between 12-13 volts when the car it stationary and not running and around 14.5 when the car is running. Normal battery readings.
The odd thing is that it says that the front left sensor is getting a reading of whoppy 650.4 km/h Very Happy Unplugging the sensor wire from the harness "on fly" doesn't affect the reading so I thought ok, the ABS/ESP ecu might be faulty.
I got a used working ABS/ESP pump unit from this forum last week and changed it but guess what. Nothing changed. It's still getting that same fault from the left front sensor and it's still doing that 650.4km/h.
What is done so far:
*both front ABS sensors renewed
*battery died last summer so it was replaced
*battery negative leads replaced to uprated ones, both - from engine to chassis and from battery to engine
*all the fuses are checked - inside the car and the engine compartment ones
*ABS/ECU pump unit replaced
So does anyone have any great ideas? Next I'm going to go through all the wiring around the abs unit with a multimeter. From the unit to sensors etc. Also going to perform a visual check on the same wires.. But if this doesn't help - then I feel I'm in a dead end with the car..
PostPosted: Mon Dec 16, 2013 3:30 am Up
Is the ABS ring on the driveshaft clean and undamaged?
PostPosted: Mon Dec 16, 2013 4:21 am Up
Have you checked the resistance on the sensors wiring to the pump? That would be my guess
Kale
PostPosted: Mon Dec 16, 2013 5:13 am Up
The rings are undamaged, forgot to add it to the list of things that have been checked. Also, as I said before, it gives a live feed of 650.4km/h from the front left sensor, even when the car is not running.
And yes, my next stop on this quest is to measure the wires from the pump to the sensor connector. Damn it would be neat to remove the wiring harness from the car and check every wire for breakups...
I just remembered, the car had a immobiliser fault last winter. It was sorted by the dealership at that time and the fault was somewhere around the same spots in wiring that had corroded from the inside due to water ingress from a connector somewhere (water rising up inside the wiring starting from the connector, capillary effect). As I said, this isn't my car so I can't remember clearly.. I'll ask the friend of mine about that if he remembers.
306 S16, 306 GTI-6, 605 SV24, 205 GTI-6, 2x405 Mi16, VW T3 1.9TD/AAZ, Audi TT mk2 3.2 quattro, Audi A6 2.7 biturbo quattro
Kale
PostPosted: Wed Dec 18, 2013 7:47 am Up
One wire, the white one going to the sensor plug from the abs unit, was almost cut in half. Cut it, soldered it and ABS is now working.
BUT
ESP warning light is still on, PP2000 gives an error code Flywheel angle sensor coherence under from the ABS/ESP unit, what could this mean?
Kale
PostPosted: Wed Dec 18, 2013 10:06 am Up
I don't remember seeing that fault with the old abs/esp unit.. Could the "new" unit be somewhat faulty? It says it's a permanent fault and won't go away when I try to erase the error codes.
iNTEGRALE
PostPosted: Wed Dec 18, 2013 10:34 am Up
Have your car hid conversion?
Ballast create lot of interferences on abs unit.
Please apologize my ugly English (if you want can correct me MP, thanks)
Kale
PostPosted: Wed Dec 18, 2013 10:40 am Up
No hid conversion on this one.
mtempsch
PostPosted: Wed Dec 18, 2013 1:17 pm Up
You sure it said flywheel? I don't see what effect the flywheel would have on ABS/ESP (but might just be lack of knowledge on my part though) - but there is an steering wheel angle sensor that tells the ESP system how you're trying to steer the car, compared to how it senses the car actually behave... As I understand it this may need recalibration after work on the front suspension / steering.
Silvermetallic 2004 206 RC
Kale
PostPosted: Wed Dec 18, 2013 2:25 pm Up
I'm 100% sure, it said Permanent fault. Flywheel angle sensor. Coherent.
It was quite a wtf moment for me also, and it showed it when I searched for error codes on ABS/ESP. No fault codes on engine or BSI. Steering angle sensor has been calibrated a couple of times actually.
I'm changing the old ABS unit back on tomorrow because it didn't do this. And I believe it's in working condition because the fault was in the wiring.
I found an old topic here on the same forum about similar problem but there is no info about how it ended..
www.206info.co.uk/Foru...55672.html
Kale
PostPosted: Sat Dec 21, 2013 9:58 am Up
Problem is sorted.
The car disliked the UK ABS/ESP unit, changed the original back on (as the fault was in the wiring) and everything works like charm. Now I only need to find a catalytic converter somewhere to get it pass MOT (as there is only a empty cat shell with a straight pipe running through on the car at the moment).
