Posted: Tue Dec 24, 2013 9:39 pm |
For those who aren't aware, the brake servo is on the left hand side of the peugeots, mainly because they're typically left hand drive, then converted for the UK (duh). This means that there's a metal tube that goes from the left side, to the right side (for your breaking)... My brother, being the smart a**e that he is, noticed that there's a slight "pedal" above the brake servo, attached to the tubing, that DOES allow you to slam on the anchors... He was highly amused as you could imagine. Bravo Peugeot
Posted: Wed Dec 25, 2013 1:17 am |
You need to get the under dash trim panel. It also stops people accidentally kicking the brake light switch.
Posted: Wed Dec 25, 2013 5:04 am |
This was in the papers a few years ago - I think the 206 was ones where it wasn't as obvious. Some woman said her child slammed the brakes on on the motorway
Posted: Wed Dec 25, 2013 9:35 am |
| macca1411 wrote: |
| You need to get the under dash trim panel. It also stops people accidentally kicking the brake light switch. |
Ah, does yours have one then? Me and my mate both don't have them in our pugs, so we just thought it was standard. The spots rather high up, so it'd be odd for it to be hit unless someones doing it on purpose.
| Harry wrote: |
This was in the papers a few years ago - I think the 206 was ones where it wasn't as obvious. Some woman said her child slammed the brakes on on the motorway  |
Blimey! bet that'd be a shocker, haha. Yeah, well, I didn't think it was that obvious either. We know the brake servo was over there, but believed it would be in the engine bay, not showing under the glove box compartment. Mad design idea there
Posted: Wed Dec 25, 2013 10:20 am |
The brake bar you mean? Hence why the later models have a trim added, ive just stuffed all my wiring back there
It makes sense, as it makes them by far easier to work on, but more importantly kerps the cost down as if you notice closely there is two holes in the bulk head for left or right hand drive.
| Team Impossible Possible
Posted: Wed Dec 25, 2013 2:55 pm |
| Addaz wrote: |
It makes sense, as it makes them by far easier to work on, but more importantly kerps the cost down as if you notice closely there is two holes in the bulk head for left or right hand drive. |
Yeah, the brake bar. Mines an 05 and doesn't have the trim, which is strange. May have to get one!:)
Posted: Wed Dec 25, 2013 3:41 pm |
| DSWR wrote: |
| Addaz wrote: |
Yeah, the brake bar. Mines an 05 and doesn't have the trim, which is strange. May have to get one!:) |
I will take a picture as a 55 plate one i did major electrical repairs on had it. 3 Clips a bar plastic welded to the lower dash board
Posted: Wed Dec 25, 2013 4:14 pm |
Braking.
Posted: Wed Dec 25, 2013 10:11 pm |
| Addaz wrote: |
| DSWR wrote: |
| Addaz wrote: |
I will take a picture as a 55 plate one i did major electrical repairs on had it. 3 Clips a bar plastic welded to the lower dash board |
Cheers, Pal:) appreciate the help
Apologies:) well spotted! fixed now
