Online Now [144]:
Visitors: 143
Today: 68290
Total: 142689629
Forums › The Car › 206 Problems › Peugeot 206 LX 1.1 Keeps cutting out.
JoshA
PostPosted: Sun Jan 05, 2014 10:01 am Up
Hi,
I have resorted to this forum as a call for help.
I am 19 years of age and finally got my first car a few months ago, i was made up with it! Until, the car started to cut out...
At first it was only every now and again the car would choose to do it therefore i ignored the signs and it began to get worse. It now cuts out near enough every time you set off in first and even sometimes when you are driving down the road in any gear.
When i plug in the diagnostic i am given an error message that is the idle air control system therefore this is why i have chosen to replace the sensors so close to the idle air control system. I have one more sensor to replace and then all sensors have been replaced.
I in the end gave up and decided to take it to a garage, they have said that it is an ECU fault although i have done my research and come across that if it was an ECU fault then the car would run absolutely terrible and it runs perfectly fine until it cuts out.
Does anybody have any idea on how to get my little baby back up on the road?! I don't fancy having to splash out on a new car (You know how the insurance costs etc are these days for people my age!)
Thank you in advance!
PostPosted: Sun Jan 05, 2014 12:00 pm Up
Hi welcome to the forum
Which sensor have you got left to replace. A simple clean might solve it click here
One thing you could check is the negative lead from the battery to the gearbox. Quite common for these to corrode at the gearbox end and cause the car to stall.
Bigbenj_08
PostPosted: Sun Jan 05, 2014 12:26 pm Up
Yep the clean linked above sorted my cutting out.
Aegean Blue 1.6 16v Sport
JoshA
PostPosted: Sun Jan 05, 2014 5:06 pm Up
Thank you for your help. I will give the carb a good clean tomorrow thats the only thing i havn't either replaced or cleaned.
I will keep you updated. Thank you for your response!
