Online Now [463]:
Visitors: 462
Today: 20967
Total: 105463005
Forums › The Car › 206 Problems › Torsion bar
Torsion bar
connorc206
PostPosted: Thu Jan 02, 2014 4:11 pm Up
Hey, my last 206 was lowered as i paid a friend to do the torsion bar for me, and me and my friends are confident to tackle it on my new one, except i have a rounded torx bolt on my torsion bar which has halted lowering my car, what is the best and easiest way of getting it out without too much hassle
cheers
Kale
PostPosted: Thu Jan 02, 2014 4:29 pm Up
Rounded torx? Hit it with a flat chisel tool+hammer from the side. Should unwind it, worked every time for me. One last option is to weld a nut on the torx bolt but try the other method first.
306 S16, 306 GTI-6, 605 SV24, 205 GTI-6, 2x405 Mi16, VW T3 1.9TD/AAZ, Audi TT mk2 3.2 quattro, Audi A6 2.7 biturbo quattro
PostPosted: Fri Jan 03, 2014 1:20 am Up
I've used a work working chisel before. Cuts into the metal nicely and knocks it out nicely.
connorc206
PostPosted: Fri Jan 03, 2014 3:43 am Up
Cheers I'll try that, it got to the point where it's just a circle.. If that fails I'll just have to weld a nut onto it
