Latest: Stu-mill
Overall: 17131
Online Now [341]:
Visitors: 340
Today: 12214
Total: 104697852
Forums › The Car › 206 Talk › 206 passenger driveshaft
hilton_marc
PostPosted: Sun Jan 05, 2014 5:01 am Up
Hey my passenger side driveshaft needs replacing ive got the part and going to give it a go today, Is it straight forward anything i need to look out for ?
macj
PostPosted: Sun Jan 05, 2014 5:52 am Up
Drop your gear oil into a clean container if you are keeping it.... or you can chance swapping the shafts without losing too much and just topping up. I would change the oil while your there Wink
rlees85
PostPosted: Sun Jan 05, 2014 10:29 am Up
Ball joint was the hardest bit for me. Haven't really got any tips for it just unless you've done it before expect to spend a few hours swearing at it
RichardEke
PostPosted: Sun Jan 05, 2014 11:45 am Up
I found these useful:
www.206info.co.uk/Foru...46498.html
www.206info.co.uk/Foru...t=341.html
I found taking the big Torx bolt out, nearest the front bumper, just made it that bit easier to get the ball joint out, using spring compressors would be the best bet though.
Used a 12point spanner on the torx bolts, found it easier.
Regards, Richard.
