Posted: Fri Jan 03, 2014 7:18 am |
Hi all,
Does anyone know if mud flaps were an optional extra or accessory on the GTi 180?
I've come across a car that has them fitted, they look factory and standard but not sure if they are genuine or after market.
Any further info or part details would be great.
Posted: Fri Jan 03, 2014 7:22 am |
my 180 never came with the mudflaps and i'm sure none of them did but they available through peugeot and are very cheap, I did post a thread with the part no.s for the front/rear but not sure where on here lol
Posted: Fri Jan 03, 2014 7:25 am |
Posted: Fri Jan 03, 2014 7:31 am |
Anyone know how to fit them?
I've got a pair of oem rears for sports bumpers but couldnt figure out how to get them on!
Posted: Fri Jan 03, 2014 8:00 am |
Bigbenj_08 wrote: |
I've got a pair of oem rears for sports bumpers but couldnt figure out how to get them on! |
you'll need to jack the rear of the car up and maybe even take the wheel off each side then they just screw to the inside facings of the bumper
Posted: Fri Jan 03, 2014 11:26 am |
Ahh that's what I thought... didnt fancy drilling into my bumper!
Posted: Fri Jan 03, 2014 1:52 pm |
Trade Rating: +59
MattyP wrote: |
Bigbenj_08 wrote: |
you'll need to jack the rear of the car up and maybe even take the wheel off each side then they just screw to the inside facings of the bumper |
Pretty sure it's just the arch liner, can't remember using any tools other than a screwdriver so it must have only been the soft plastic of the arch liner.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Fri Jan 03, 2014 2:33 pm |
Lecktorious wrote: |
MattyP wrote: |
Bigbenj_08 wrote: |
Pretty sure it's just the arch liner, can't remember using any tools other than a screwdriver so it must have only been the soft plastic of the arch liner. |
Thats what I assumed it would be... but I couldnt figure out how to arrange the clips!
Maybe I'll have a coffee and try again!
Posted: Fri Jan 03, 2014 4:56 pm |
MattyP wrote: |
Bigbenj_08 wrote: |
You could be right, i never fitted the rears on mine, only the front
Posted: Sat Jan 04, 2014 12:32 am |
These are only fitted on the front. Nothing at the rear.
Posted: Sat Jan 04, 2014 2:04 am |
I have them fitted on the rear. There are a couple of U clamps which go around the lip of the bumper in the arch
and then this bracket underneath
Not sure if they are OEM or not as they were on when I got the car, but might give you some idea how they fit
Posted: Sat Jan 04, 2014 3:59 am |
Fit them as intended to the front and as the tyres are wide the flaps do nothing. They need drilling and fitting further out.
