Latest: tebas93089
Overall: 17179
Online Now [82]:
Visitors: 81
Today: 21218
Total: 138494914
Forums › The Car › 206 Problems › New clutch
New clutch
darrencol
PostPosted: Sat Jan 04, 2014 4:40 pm Up
Hi all,
I've just had a new clutch, fork and nose cone fitted to my car and now the clutch pedal feels VERY light and also the biting point seems to be quite high (not any higher than it was before but I thought with a brand new clutch the biting point should be much lower down). I just want to ask if the clutch needs some sort of adjustment after being fitted that perhaps wasn't done? I have a '05 206 GTi 180.
Thanks,
Darren
rlees85
PostPosted: Sun Jan 05, 2014 11:27 am Up
As far as I know due to the hydraulic clutch (that is self adjusting) that is about normal... As long as it doesn't slip!
NayNay1991x
PostPosted: Mon Jan 06, 2014 2:49 pm Up
I had a brand new clutch and cable and biting point isn't low I personally like it high rather than too low, correct me if I'm wrong but I hear most peugeots or just 206 have high biting points.
206 1.4i GLX 1999
instagram.com/nay206pug/#
broadblaster
PostPosted: Mon Jan 06, 2014 3:01 pm Up
both my 180's were the same when i had new clutch's fitted and they have never been a prblem since they were done.
on a back road playing
darrencol
PostPosted: Mon Jan 06, 2014 3:28 pm Up
That's alright then. Wasn't sure if it was a problem but obviously it's normal. Thanks Smile
PostPosted: Mon Jan 06, 2014 3:45 pm Up
I bet it needs bleeding. It should be nice and smooth. What are gear changes like.
darrencol
PostPosted: Mon Jan 06, 2014 3:49 pm Up
ehhh I suppose they're super smooth. You can feel the jolt forward when acceleration stops and it comes out of gear but when putting it back into the next gear and releasing the clutch you can't really feel it going into a new gear, it just feels like it's still in neutral until I accelerate again
PostPosted: Mon Jan 06, 2014 4:07 pm Up
I would get it bled.
darrencol
PostPosted: Mon Jan 06, 2014 4:26 pm Up
Is that expensive?
PostPosted: Tue Jan 07, 2014 4:28 am Up
You can do it yourself. A garage shouldn't charge much.
southwestchap
PostPosted: Tue Jan 07, 2014 5:00 am Up
Just changed the clutch in my 1.4HDi and had to bleed it up again. Not too bad to do, easy with 2 of you.
PostPosted: Tue Jan 07, 2014 5:35 am Up
Easier with an easibleed kit!
