Latest: tebas93089
Overall: 17179
Online Now [149]:
Visitors: 148
Today: 34592
Total: 137806536
Forums › The Car › 206 Problems › Few problems I'm having ATM......
W573ADS
PostPosted: Wed Jan 08, 2014 2:19 pm Up
Hey guys hope you can help with these problems:
1, accelerate and pulls hard to the right and to the left when braking, I changed the wishbones and drop links 3-4 months ago.
2, banging from suspension when turning lock to lock, I suspect top mounts but would like some reassurance Smile
3, steering wheel shakes left to right at speeds as low as 25mph but only really noticeable when cruising along
4, a rattle/vibration coming through my pedals when driving at higher rpm's
5, loud bang whenever I go over a bump coming from n/s front arch area
Hope you can help with this Smile
Thanks in advance
W573ADS
PostPosted: Wed Jan 08, 2014 2:20 pm Up
Also crunches gears most of the time between 1st and 2nd and is really hard to get into gear of a morning Sad
Thanks Smile
Tolkienfan001
PostPosted: Wed Jan 08, 2014 2:35 pm Up
Trade Rating: +13
Sounds like several issues. Gear linkage or gearbox oil level maybe. Balance and tracking and any number of suspension issues.
How old is the car? What kind of life has it had? How well has it been looked after? Any issues on the last mot?
2005 1.4 16v Sport
Check out my 206 here!
W573ADS
PostPosted: Wed Jan 08, 2014 3:51 pm Up
It's a 2000, has 85k on the clock, I've done 4k of that in the last 3-4 months, being honest I do drive it hard sometimes, before me it was sitting for 6-8 months and mot flew through, since I've had it I've done:
Front wishbones
Front ARB links
Alloys + tyres
Rear shoes
Service
Head gasket
Cam belt
Water pump
Core plug in head
Wheel balancing and tracking with more tyres
Spent a bit on her tbh lol
commandosqueak
PostPosted: Wed Jan 08, 2014 4:08 pm Up
sound to me as oil level in box it low or its a syncro ring/ linkage issue. could have knackered top mounts and could have an issue with the brakes if its pulling to one side too. I would take the front running gear apart and give it a good clean and inspection. anything that looks knackered replace. make sure everything is done up to correct torque and hopefully it should cure it
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
W573ADS
PostPosted: Wed Jan 08, 2014 4:10 pm Up
Front brakes were basically brand new when I had the car and are still pretty good nic tbf
W573ADS
PostPosted: Thu Jan 09, 2014 6:15 pm Up
What grade of gearbox oil and how much should it have in there?
PostPosted: Fri Jan 10, 2014 12:59 pm Up
75W80 Total BV only.
x2 litres.
PostPosted: Fri Jan 10, 2014 2:30 pm Up
Vibration from front could be damaged tyres. if the car was stood for a long time and tyres were soft or flat the side walls could be damaged giving the steering wheel shakes that you describe.
To be honest with the mix of symptoms you have I would get a trusted garage or mate to give it a good look over and test drive.
Remotely fault finding combined issues isn't easy.
Gear selection could be clutch worn or adjustment or as already suggested in posts by others.
PostPosted: Fri Jan 10, 2014 6:20 pm Up
True, I had exactly this the other day..
Different tyre and symptom gone.
PostPosted: Fri Jan 10, 2014 11:07 pm Up
He said he had new alloys and tyres.
It could be warped discs causing the vibration.
I would change the top mounts, drop links and have it tracked if it was me.
W573ADS
PostPosted: Sun Jan 12, 2014 3:39 pm Up
Think I've narrowed the wobble down to maybe a buckled front left wheel as it's just eaten through the tyre and at low speeds it pulls the the left at the same time as a rotation of the wheel, putting a new tyre on it tomoz morning, getting it balanced and checked out and put back on the rear, the loud bang when going over speed bump is still there and getting worse though, plan to investigate the weekend coming Smile
