Forums › The Car › 206 Talk › obd reader for pre plex 2000 gti |
Posted: Sat Jan 11, 2014 5:01 am |
is there any devices that work on the pre plex gti ??
Posted: Sat Jan 11, 2014 7:34 am |
All of them?
I've got an Autel Maxiscan 509 which was cheap but full of functions. My car is a pre plex December 2000 built car. It's useless on mine though because the ECU doesn't run the engine anymore.
Do all 206's work with EOBD scanners? It's not as simple as a plexed/pre plexed thing.
My in-laws have a W reg Vauxhal Zafira. It's pre EOBD (2001?) though so the scanner doesn't work. How old is your 206?
Posted: Sat Jan 11, 2014 8:00 am |
its a 2000 same as your think its a december one, the reason for asking is i searched and everyone woth the obd 2 came up that pre plex dont readout
Posted: Sat Jan 11, 2014 11:46 am |
They do. Mine work fine. I've forgotten what the difference is between EOBD, OBD, EOBD 2 but my Maxiscan works fine.
Posted: Sat Jan 11, 2014 12:23 pm |
just looked at the maxi scan, does it plug into a laptop or just display on the little screen the numbers
Posted: Sat Jan 11, 2014 12:49 pm |
Displays live data on the screen. I think data can be output to a laptop too.
Posted: Sun Jan 12, 2014 9:11 am |
i have a Autel MaxiScan MS300, works a treat on my 2006 gti and my old 2001 1.4 8v but wont work on my dads 2000 1.1 . dunno how much difference there is between a 2000 1.1 and a gti tho lol
