Posted: Sun Jan 12, 2014 3:05 pm |
Hi, my cig lighter works fine and gives power fine. But I was sure when I bought the car the outline of the base light up when car lights on. now does not light up. how do i change bulb. are spare bulbs easily available?
Many thanks
Posted: Sun Jan 12, 2014 3:11 pm |
bulbs are available from halfords and are the same for the mfd and heater controls, its do able but a pain in the a**e
| 2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey | |
Posted: Sun Jan 12, 2014 3:15 pm |
I couldn't work out how to replace mine.
Posted: Sun Jan 12, 2014 3:26 pm |
the easiest way is to take the console out and replace the whole unit
Posted: Tue Jan 14, 2014 10:21 pm |
Indeed, I tried replacing mine. Its a Pita to replace that bulb since you need to take it apart and there is a tiny piece of metal which makes contact that usually breaks upon touch. One thing thats easier is to just replace it. Even Clios have the same unit, so plenty.
Have a look, the bulb is in the housing to the south. A PITA to take out.
