Posted: Mon Jan 13, 2014 3:16 pm |
I have noticed that during high speed the battery light is coming on and disappearing frequently. Is this an indication of alternator failure?
When checking the battery at normal car idle speed, the output voltage is 14V. The battery is also a new one.
Cheers.
Posted: Mon Jan 13, 2014 3:32 pm |
Have you checked your alternator
Cables, battery connections etc?
| You never really learn to swear until you learn to drive | |
Posted: Mon Jan 13, 2014 3:38 pm |
Is the belt squeezing?
Posted: Mon Jan 13, 2014 4:41 pm |
| ukskater01 wrote: |
Cables, battery connections etc? |
The negative battery cable was a little loose, I'm not sure if something like this may cause the battery light to come on while driving.
Posted: Mon Jan 13, 2014 4:42 pm |
| Steve206 wrote: |
| Is the belt squeezing? |
I will be so interested to check this point!
Posted: Mon Jan 13, 2014 5:08 pm |
You might have a problem with your AUX. Belt tensioner ,which cause the belt to be loose when speeding.
