Latest: Beduff1977
Overall: 17134
Online Now [618]:
Visitors: 617
Today: 165659
Total: 109160378
Forums › The Car › 206 Problems › 2.hdi leaking oil from injector and lacks power under load
ChapmanHDI
PostPosted: Tue Jan 14, 2014 8:11 am Up
hi,
i have a problem with my 206
i was on my way home last night, seemed fine down the hill from work then it started chugging on the flat like it was low on fuel or miss firing but no poping noise bit of a clunking
i noticed oil was low and there seemed to be an explosive leak around the cam belt area, hard to see really but it wason the altanator, radiator and all around there.
then today i noticed a little oil bubbling from the injector
thinking piston ring, gasket or something along those lines
please if anyone has any ideas? or if there's something i can do to test it or if this is the death of the car Sad
thanks steven
206HDI
PostPosted: Tue Jan 14, 2014 1:48 pm Up
you might need new injectors seals
commandosqueak
PostPosted: Tue Jan 14, 2014 6:45 pm Up
sounds like something major..
check the oil and the level. take the timing belt cover off and find where the oil is coming from. could try a compression test. it may be worth removing your injectors and checking the seals etc. maybe that will shed some light. im sure one of the experts may be able to help more than i can
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
DREWDEN
PostPosted: Wed Jan 15, 2014 5:41 am Up
Is the EML light on by any chance.
206 2ltr Hdi glx 53 plate
