Latest: Beduff1977
Overall: 17134
Online Now [490]:
Visitors: 489
Today: 64676
Total: 109235532
Forums › The Car › 206 Problems › Dead reversing light
davepug
PostPosted: Thu Jan 16, 2014 6:06 am Up
Hi All
Had my 206 for coming up to 4 years, and never had a reversing light working on it. I must admit, that ive not tried that hard to get rid of it, but it was my new years resolution to get it sorted.
Ive tried the bulbs, and ive had a look at the fuse, none have solved my problem.
So whats next out of the reversing light switch or new bulb holders??
Cheers all.
PostPosted: Thu Jan 16, 2014 6:16 am Up
Use a multi-meter to check power is getting to the bulb holders, if not, then check the continuity through the switch when reverse is engaged.
dannyboy-gti
PostPosted: Thu Jan 16, 2014 1:19 pm Up
Even easier to visually look to see if the switch is connected first? Sometimes left disconnected through other work like a clutch.
PostPosted: Thu Jan 16, 2014 1:29 pm Up
Also check that the bulb holder is earthed. Lots of bulbs don't work because the holder no longer has continuity to earth.
AndrewR2211
PostPosted: Fri Jan 17, 2014 8:32 am Up
Reverse light switch, will probably be that, i had to change mine, 10 minute job
My 206 Sport
