Online Now [210]:
Visitors: 210
Today: 22778
Total: 143220983
Forums › The Car › 206 Problems › how to remove this?(headlight)
Lex206
PostPosted: Sat Jan 18, 2014 7:36 am Up
i need that connector marked in yellow to install my new headlights and also need the wires that go to the bulbs.
but how do you remove that connector?
i took out the plastic'pin'and found out i can almost push the conector inside the headlight but there is no way you can remove it.
it looks like the connector is one piece and i think somewhere on this forum i found a pic of that thing also in one piece.
Megane 225 RS
PostPosted: Sat Jan 18, 2014 12:56 pm Up
Well as far as I know,this plug can't be removed ,what is the problem,going from Phase 1 to Phase 2 headlights?
Lex206
PostPosted: Sat Jan 18, 2014 2:09 pm Up
i bought fake morettes,want to use the wires and connector from the Original lights on the morette's and then connect it to the Original wires.
Megane 225 RS
iainlovatt
PostPosted: Sat Jan 18, 2014 2:21 pm Up
pull hard with pliers. Smile Removed one couple days back! Smile
(My Garage)
Lex206
PostPosted: Sat Jan 18, 2014 2:33 pm Up
are you serious?
and that rubber under the connector..that wont go through
Megane 225 RS
Jack123
PostPosted: Sat Jan 18, 2014 3:29 pm Up
I have some H4 to H7 Adapters if you want to avoid pulling it out? £5 posted.
Shameless sales post.
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
