Latest: jackrox1992
Overall: 17186
Online Now [726]:
Visitors: 725
Today: 10334
Total: 148397167
Forums › The Car › 206 Problems › Rear window seal?
Rear window seal?
frenchfrog40
PostPosted: Tue Jan 21, 2014 4:57 am Up
Hi
The rear passenger window on my 3 door xsi is leaking. The leak is coming from the top right "bolt" that holds the window on. Iv been told this is the rubber grommet... i have no idea what i need to buy to fix this. anyone know?
Iv had:
mtempsch
PostPosted: Tue Jan 21, 2014 7:40 am Up
It's a flat rubber gasket. Doubt anyone other than Pug dealers (and possibly Citroen dealers if it's a shared part within PSA) have the exact size.
I did a temporary fix with a normal O-ring of suitable size, but that didn't stand up well against the high-pressure washer...
A better quick fix would probably be to apply silicone around the hole in the glass, to a dimension similar to the gasket. Let dry before assembling if ease of later disassembly is a concern. Keep the surface as smooth as possible so the head of the fastener has a nice surface to seal against (not a problem id reassembled when not yet dry).
Don't have the part number for the gaskets, but I remember them to be not very costly. I'd say drop by, or call up, your local dealer and describe what you need (though I know that appears to be a strange and fearful concept Razz to many on the site).
Silvermetallic 2004 206 RC
frenchfrog40
PostPosted: Thu Jan 23, 2014 5:05 am Up
lol. ok thanks, ill pop down there next week or something.
Iv had:
